You are here: FME Server Administrator's Guide > Performing an Installation for High Availability > Installing for Core Failover > Post-Configuration Scripts
After configuring the database, you must run three scripts to finish completing the installation. These scripts enable the installed services, sample workspaces, and notification subscribers.
  1. Ensure that FME Server is running.
  2. On Windows, run the following scripts:
  3. On Linux, run the following scripts:
